Skip to main content
Version: current
Bridge IGMP/MLD snooping
IGMP (Internet Group Management Protocol) and MLD (Multicast Listener Discovery) snooping are bridge features that enable the bridge to passively listen to IGMP/MLD network communication and use this information to make intelligent forwarding decisions for multicast traffic. By default, bridges flood all multicast traffic to every bridge port, similar to how broadcast traffic is handled. This default behavior may not be ideal for certain applications such as multicast video streaming or SDVoE (SDVoE) deployments. IGMP/MLD snooping addresses this issue by forwarding multicast traffic only to ports where interested clients are subscribed. See the IGMP/MLD network concept diagram below.
The RouterOS bridge implementation supports IGMP versions 1, 2, and 3, as well as MLD versions 1 and 2. This implementation is based on RFC4541, and the respective protocols specifications are defined in RFC1112 (IGMPv1), RFC2236 (IGMPv2), RFC3376 (IGMPv3), RFC2710 (MLDv1), and RFC3810 (MLDv2).
warning
Source-specific multicast forwarding is not supported for IGMPv3 and MLDv2.
IGMP Configuration Diagram
The bridge processes IGMP/MLD messages only when igmp-snooping is enabled. Additionally, the bridge must have an active IPv6 address to process MLD packets. Initially, the bridge does not restrict any multicast traffic and floods all multicast packets. Once an IGMP/MLD querier is detected—by receiving an IGMP/MLD query message (either from an external multicast router or locally from the bridge interface with multicast-querier enabled)—the bridge begins restricting unknown IP multicast traffic and forwards only known multicast streams from the Multicast Database (MDB). IGMP and MLD querier detection operate independently; detecting an IGMP querier does not affect IPv6 multicast forwarding, and vice versa. Querier detection also does not restrict the forwarding of non-IP and link-local multicast groups, such as 224.0.0.0/24 and ff02::1.
danger
CRS3xx series devices with Marvell-98DX3236, Marvell-98DX224S, or Marvell-98DX226S switch chips cannot distinguish between non-IP, IPv4, and IPv6 multicast packets once an IGMP or MLD querier is detected. This means the switch will stop forwarding all unknown multicast traffic (regardless of protocol) when a querier is detected. This limitation does not apply to certain link-local multicast address ranges, such as 224.0.0.0/24 or ff02::1.
Configuration options
This section describes the IGMP and MLD snooping bridge configuration options.
Sub-menu: /interface/bridge
PropertyDescription
igmp-snooping (yes | no; Default: no)Enables IGMP and MLD snooping.
igmp-version (2 | 3; Default: 2)Selects the IGMP version in which IGMP membership queries will be generated when the bridge interface is acting as an IGMP querier. This property only has an effect when igmp-snooping and multicast-querier are set to yes.
last-member-interval (time; Default: 1s)When the last client on the bridge port unsubscribes from a multicast group and the bridge is acting as an active querier, the bridge will send a group-specific IGMP/MLD query, to make sure that no other client is still subscribed. The setting changes the response time for these queries. In case no membership reports are received in a certain time period (last-member-interval * last-member-query-count), the multicast group is removed from the multicast database (MDB).
If the bridge port is configured with fast-leave, the multicast group is removed right away without sending any queries.
last-member-query-count (integer: 0..4294967295; Default: 2)How many times should last-member-interval pass until the IGMP/MLD snooping bridge stops forwarding a certain multicast stream. This property only has an effect when igmp-snooping and multicast-querier are set to yes.
membership-interval (time; Default: 4m20s)The amount of time after an entry in the Multicast Database (MDB) is removed if no IGMP/MLD membership reports are received on a bridge port. This property only has an effect when igmp-snooping is set to yes.
mld-version (1 | 2; Default: 1)Selects the MLD version in which MLD membership queries will be generated, when the bridge interface is acting as an MLD querier. This property only has an effect when the bridge has an active IPv6 address, igmp-snooping and multicast-querier are set to yes.
multicast-querier (yes | no; Default: no)Multicast querier generates periodic IGMP/MLD general membership queries to which all IGMP/MLD capable devices respond with an IGMP/MLD membership report, usually a PIM (multicast) router or IGMP proxy generates these queries.
By using this property you can make an IGMP/MLD snooping enabled bridge generate IGMP/MLD general membership queries. This property should be used whenever there is no active querier (PIM router or IGMP proxy) in a Layer2 network. Without a multicast querier in a Layer2 network, the Multicast Database (MDB) is not being updated, the learned entries will timeout and IGMP/MLD snooping will not function properly.
Only untagged IGMP/MLD general membership queries are generated, IGMP queries are sent with IPv4 0.0.0.0 source address, MLD queries are sent with IPv6 link-local address of the bridge interface. The bridge will not send queries if an external IGMP/MLD querier is detected (see the monitoring values igmp-querier and mld-querier).
multicast-router (disabled | permanent | temporary-query; Default: temporary-query)A multicast router port is a port where a multicast router or querier is connected. On this port, unregistered multicast streams and IGMP/MLD membership reports will be sent. This setting changes the state of the multicast router for a bridge interface itself. This property can be used to send IGMP/MLD membership reports and multicast traffic to the bridge interface for further multicast routing or proxying. This property only has an effect when igmp-snooping is set to yes.
  • disabled - disabled multicast router state on the bridge interface. Unregistered multicast streams and IGMP/MLD membership reports are not sent to the bridge interface regardless of what is configured on the bridge interface.
  • permanent - enabled multicast router state on the bridge interface. Unregistered multicast streams and IGMP/MLD membership reports are sent to the bridge interface itself regardless of what is configured on the bridge interface.
  • temporary-query - automatically detect multicast router state on the bridge interface using IGMP/MLD queries.
querier-interval (time; Default: 4m15s)Changes the timeout period for detected querier and multicast-router ports. This property only has an effect when igmp-snooping is set to yes.
query-interval (time; Default: 2m5s)Changes the interval at which IGMP/MLD general membership queries are sent out when the bridge interface is acting as an IGMP/MLD querier. The interval takes effect when the last startup query is sent. This property only has an effect when igmp-snooping and multicast-querier are set to yes.
query-response-interval (time; Default: 10s)The setting changes the response time for general IGMP/MLD queries when the bridge is acting as an IGMP/MLD querier. This property only has an effect when igmp-snooping and multicast-querier are set to yes.
startup-query-count (integer: 0..4294967295; Default: 2)Specifies how many times general IGMP/MLD queries must be sent when the bridge interface is enabled or active querier times out. This property only has an effect when igmp-snooping and multicast-querier are set to yes.
startup-query-interval (time; Default: 31s250ms)Specifies the interval between startup general IGMP/MLD queries. This property only has an effect when igmp-snooping and multicast-querier are set to yes.
Sub-menu: /interface/bridge/port
PropertyDescription
fast-leave (yes | no; Default: no)Enables IGMP/MLD fast leave feature on the bridge port. The bridge will stop forwarding multicast traffic to a bridge port when an IGMP/MLD leave message is received. This property only has an effect when igmp-snooping is set to yes.
multicast-router (disabled | permanent | temporary-query; Default: temporary-query)A multicast router port is a port where a multicast router or querier is connected. On this port, unregistered multicast streams and IGMP/MLD membership reports will be sent. This setting changes the state of the multicast router for bridge ports. This property can be used to send IGMP/MLD membership reports and multicast streams to certain bridge ports for further multicast routing or proxying. This property only has an effect when igmp-snooping is set to yes.
  • disabled - disabled multicast router state on the bridge port. Unregistered multicast streams and IGMP/MLD membership reports are not sent to the bridge port regardless of what is connected to it.
  • permanent - enabled multicast router state on the bridge port. Unregistered multicast and IGMP/MLD membership reports are sent to the bridge port regardless of what is connected to it.
  • temporary-query - automatically detect multicast router state on the bridge port using IGMP/MLD queries.
unknown-multicast-flood (yes | no; Default: yes)Changes the multicast flood option on the bridge port. It only controls the egress traffic. When enabled, the bridge allows flooding multicast packets to the specified bridge port, but when disabled, the bridge restricts multicast traffic from being flooded to the specified bridge port. The setting affects all multicast traffic. This includes non-IP, IPv4, IPv6, and the link-local multicast ranges (e.g. 224.0.0.0/24 and ff02::1).
Note that when igmp-snooping is enabled and an IGMP/MLD querier is detected, the bridge will automatically restrict unknown IP multicast from being flooded, so the setting is not mandatory for IGMP/MLD snooping setups.
When using this setting together with igmp-snooping, the only multicast traffic that is allowed on the bridge port is the known multicast from the MDB table.
Sub-menu: /interface/bridge/mdb
PropertyDescription
bridge (name; Default: )The bridge interface to which the MDB entry is going to be assigned.
disabled (yes | no; Default: no)Disables or enables the static MDB entry.
group (ipv4 | ipv6 address; Default: )The IPv4 or IPv6 multicast address. Static entries for link-local multicast groups 224.0.0.0/24 and ff02::1 cannot be created, as these packets are always flooded on all ports and VLANs.
ports (name; Default: )The list of bridge ports to which the multicast group will be forwarded.
vid (integer: 1..4094; Default: )The VLAN ID on which the MDB entry will be created, only applies when vlan-filtering is enabled. When the VLAN ID is not specified, the entry will work in shared-VLAN mode and dynamically apply on all defined VLAN IDs for particular ports.
Monitoring and troubleshooting
This section describes the IGMP/MLD snooping bridge monitoring and troubleshooting options.
To monitor learned multicast database (MDB) entries, use the print command.
PropertyDescription
bridge (read-only: name)Shows the bridge interface the entry belongs to.
group (read-only: ipv4 | ipv6 address)Shows a multicast group address.
on-ports (read-only: name)Shows the bridge ports that are subscribed to a certain multicast group.
vid (read-only: integer)Shows the VLAN ID for the multicast group, only applies when vlan-filtering is enabled.
[admin@MikroTik] /interface/bridge/mdb/print
Flags: D - DYNAMIC
Columns: GROUP, VID, ON-PORTS, BRIDGE
# GROUP VID ON-PORTS BRIDGE
0 D ff02::2 1 bridge1 bridge1
1 D ff02::6a 1 bridge1 bridge1
2 D ff02::1:ff00:0 1 bridge1 bridge1
3 D ff02::1:ff01:6a43 1 bridge1 bridge1
4 D 229.1.1.1 10 ether2 bridge1
5 D 229.2.2.2 10 ether3 bridge1
ether2
6 D ff02::2 10 ether5 bridge1
ether3
ether2
ether4
To monitor the current status of a bridge interface, use the monitor command.
PropertyDescription
igmp-querier (none| interface & IPv4 address)Shows a bridge port and source IP address from the detected IGMP querier. Only shows the detected external IGMP querier, the local bridge IGMP querier (including IGMP proxy and PIM) will not be displayed. The monitoring value appears only when igmp-snooping is enabled.
mld-querier (none| interface & IPv6 address)Shows a bridge port and source IPv6 address from the detected MLD querier. Only shows the detected external MLD querier, the local bridge MLD querier will not be displayed. The monitoring value appears only when igmp-snooping is enabled and the bridge has an active IPv6 address.
multicast-router (yes | no)Shows if a multicast router is detected on the bridge interface. The monitoring value appears only when igmp-snooping is enabled.
[admin@MikroTik] /interface/bridge/monitor bridge1
state: enabled
current-mac-address: 64:D1:54:C7:3A:59
root-bridge: yes
root-bridge-id: 0x8000.64:D1:54:C7:3A:59
root-path-cost: 0
root-port: none
port-count: 3
designated-port-count: 3
fast-forward: no
multicast-router: no
igmp-querier: ether2 192.168.10.10
mld-querier: ether2 fe80::e68d:8cff:fe39:3824
To monitor the current status of bridge ports, use the monitor command.
PropertyDescription
multicast-router (yes | no)Shows if a multicast router is detected on the port. Monitoring value appears only when igmp-snooping is enabled.
[admin@MikroTik] > /interface/bridge/port/monitor [find]
interface: ether2 ether3 ether4
status: in-bridge in-bridge in-bridge
port-number: 1 2 3
role: designated-port designated-port designated-port
edge-port: no yes yes
edge-port-discovery: yes yes yes
point-to-point-port: yes yes yes
external-fdb: no no no
sending-rstp: yes yes yes
learning: yes yes yes
forwarding: yes yes yes
multicast-router: yes no no
hw-offload-group: switch1 switch1 switch1
Configuration examples
Below are described the most common configuration examples. Some examples are using a bridge with VLAN filtering, so make sure to understand the filtering principles first - bridge VLAN filtering, bridge VLAN table.
Basic IGMP snooping configuration
The first example consists only of a single IGMP snooping bridge, a single multicast source device, and a couple of multicast client devices. See a network scheme below.
IGMP Basic Setup Diagram
First, create a bridge interface with enabled IGMP snooping. In this example, there is no active IGMP querier (no multicast router or proxy), so a local IGMP querier must be enabled on the same bridge. This can be done with a multicast-querier setting. If there is no active IGMP querier in the LAN, the unregistered IP multicast will be flooded and multicast entries will always timeout from the multicast database.
/interface/bridge
add igmp-snooping=yes multicast-querier=yes name=bridge1
Then add the necessary interfaces as bridge ports.
The basic IGMP snooping configuration is finished. Use "/interface/bridge/mdb/print" command to monitor the active multicast groups. If necessary, you can configure an IP address and DHCP server on the same bridge interface.
IGMP snooping configuration with VLANs
The second example adds some complexity. There are two IGMP snooping bridges and we need to isolate the multicast traffic on a different VLAN. See a network scheme below.
IGMP VLAN Setup Diagram
First, create a bridge on both devices and add the needed interfaces as bridge ports. To change the untagged VLAN for a bridge port, use the pvid setting. Bridge1 will be acting as an IGMP querier. Below are the configuration commands for Bridge1:
/interface/bridge
add bridge=bridge1 interface=ether2 pvid=10
add bridge=bridge1 interface=ether3 pvid=10
add bridge=bridge1 interface=ether4 pvid=10
add bridge=bridge1 interface=ether5 pvid=20
add bridge=bridge1 interface=sfp-sfpplus1 pvid=10
And for the Bridge2:
/interface/bridge
add igmp-snooping=yes name=bridge1
warning
Bridge IGMP querier implementation can only send untagged IGMP queries. In case tagged IGMP queries should be sent or IGMP queries should be generated in multiple VLANs, you can configure VLAN interfaces alongside IGMP Proxy or PIM-SM. The downstream interfaces of the IGMP Proxy, as well as PIM-SM interfaces, can operate as IGMP queriers.
Make sure to configure management access for devices. It is essential when configuring a bridge with VLAN filtering. In this example, a VLAN 99 interface with an IP address is added to the bridge. This VLAN will be allowed on the tagged sfp-sfpplus1 port. Below are configuration commands for the Bridge1:
/interface/vlan
add interface=bridge1 name=MGMT vlan-id=99
/ip/address
add address=192.168.99.1/24 interface=MGMT network=192.168.99.0
/interface/bridge/vlan
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1 vlan-ids=99
/interface/vlan
/ip/address
add address=192.168.99.2/24 interface=MGMT network=192.168.99.0
Add bridge VLAN entries and specify tagged and untagged ports. The VLAN 99 entry was already created when configuring management access; only VLAN 10 and VLAN 20 should be added now. Below are the configuration commands for Bridge1:
add bridge=bridge1 untagged=ether2,ether3,ether4,sfp-sfpplus1 vlan-ids=10
add bridge=bridge1 tagged=sfp-sfpplus1 untagged=ether5 vlan-ids=20
add bridge=bridge1 untagged=ether3,ether4,sfp-sfpplus1 vlan-ids=10
Last, enable VLAN filtering. Below is the configuration command for Bridge1 and Bridge2:
/interface/bridge/set [find name=bridge1] vlan-filtering=yes
At this point, VLANs and IGMP snooping are configured and devices should be able to communicate through ports. However, it is recommended to go even a step further and apply some additional filtering options. Enable ingress-filtering and frame-types on bridge ports. Below are the configuration commands for Bridge1:
set [find interface=ether2] ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
set [find interface=ether3] ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
set [find interface=ether4] ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
set [find interface=ether5] ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
set [find interface=sfp-sfpplus1] ingress-filtering=yes
Static MDB entries
Since RouterOS version 7.7, it is possible to create static MDB entries for IPv4 and IPv6 multicast groups. For example, to create a static MDB entry for multicast group 229.10.10.10 on ports ether2 and ether3 on VLAN 10, use the command below:
add bridge=bridge1 group=229.10.10.10 ports=ether2,ether3 vid=10
Verify the results with the print command:
[admin@MikroTik] > /interface/bridge/mdb/print where group=229.10.10.10
12 229.10.10.10 10 ether2 bridge1
ether3
In case a certain IPv6 multicast group does not need to be snooped and it is desired to be flooded on all ports and VLANs, it is possible to create a static MDB entry on all VLANs and ports, including the bridge interface itself. Use the command below to create a static MDB entry for multicast group ff02::2 on all VLANs and ports (modify the ports setting for your particular setup):
add bridge=bridge1 group=ff02::2 ports=bridge1,ether2,ether3,ether4,ether5
[admin@MikroTik] > /interface/bridge/mdb/print where group=ff02::2
Flags: D - DYNAMIC
0 ff02::2 bridge1
15 D ff02::2 1 bridge1 bridge1
16 D ff02::2 10 bridge1 bridge1
ether2
ether3
ether4
ether5
17 D ff02::2 20 bridge1 bridge1
ether2
ether3
18 D ff02::2 30 bridge1 bridge1
ether2
ether3
